I have alinksys WET610N BRIDGE ADAPTER. Instead of buying yet another adapter to make a device work. Is there a setup to have this device work with WD Live
thanks
Linda
thanks
Linda
Not sure what you’re asking.
If you use a wireless bridge, you don’t configure ANY wireless info on the WDTV. The WDTV will be unaware that you even have a wireless net, and will be configured as if you’re using the on-board wired network interface.
Yes, it works fine. Just configure the bridge for your wireless network and plug the WD Live into the bridge. You don’t need to do any other configuration.
-R
