No HDMI on my Tv and I got this WDTV Play for Xmass. I bought a HDMI to component converter and tried connecting it but it’s a no go?
This should work in theory.
The resolution will be lesser but you should still get the signal
You could try testing with a different adapter.
John tks for you’re reply…I did some more research and found out I can’t use the HDMI to Component cable it has to be a CONVERTER BOX…
I ordered one and after I try it out I’ll let everyone know if it worked
Why don´t you use composite
The WDTV Play only supports HDMI or COMPOSITE (Yellow/Red/White)
(No COMPONENT Video Output … Green/Blue/Red )
You should have read the User Manual before shelling out $$$ on a HDMI to Component Converters
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705073.pdf
PAGE 12
as foetus said use Composite if your TV has no HDMI (But picture quality will be Standard Definition 480i/576i)
Want High Definition ?
Buy a FULL 1080p HD TV with HDMI…
or
if your Old TV has Component Video input … buy a Live / Live Streaming or Live Hub which support Component Video Output which is 720p/1080i
