Is there any difference between recording streamed shows and recording football games and other shows onto a DVR? Can the Hub be used to record streamed shows? I would appreciate an answer in very simple terms as I am new to all this and don’t know the jargon.
The hub doesn’t record anything, unless you are watching live TV via Hauppauge.
What is Hauppauge?
One of the apps under the “Live TV” tab
When did this come in? I have been using the same firmware for almost a year due to WD’s proclivity to break things that were working and my if it works, leave it alone philosophy.
It’s in the current firmware 3.08.14.
I don’t know anything about this stuff so I’m sorry if this sounds dumb but are you saying yes the Hub will record streamed football etc if I use the app Hauppage?
No, it will record Live TV with the Hauppauge USB Tuner adapter.
Where is the documentation on this since it obviously came out after I purchased mine? What Happauge equipment is compatible?
TonyPh12345 wrote:
Just as I thought, ATSC and clear-QAM only. I already have 4 digital tuners doing exactly that in my Windows Media PC. Thanks for the link, though. Need to keep up on what this magic box can do.
