I have been using WD hard disk over ten years, I have just bought 3TG WD30EZRX and toss about it in XP for few days, now I even can’t restore original factory settings as 3TG unpartitioned status, I tried all the partition softwares…
Obviously, the WD green 30EZRX 3TG hard disk is technically immature.
…Acronis Align Tool will not make Windows XP see the whole 3TB hard drive because it’s a simple fact that Windows XP does not support a GUID partition table. Doesn’t make a difference if the motherboard has EUFI when you’re running a 32bit operating system.
Is that right? are there any software to fix the problem that let user to use the whole 3TG WD HDD in XP 32bit?
I tried to use Windows XP 64bit and Windows 7 to partition WD 3TG, but still can not partition it, it keep showing there are only 746GB. After I use Windows 7 setup disk to delete all the 3TG partitions, but still, there are only 746GB. I think that the WD should tell user how to restore original factory settings, which is raw unpartitioned 3TG, any particular software? Acronis for WD Partition does not work at all.
I have used the following software to partition WD 3TG:
