Haven’t had issues with 4TB MyCloud so far. 3TB of data. Running firmware 3.x, everything fine.
It just stopped being accesible from Windows Explorer (though dashboard worked). So I rebooted for first time in almost a month. After that, the *** went white led. Stuck there for a couple of hours now.
No IP assigned, not accesible from dashboard or SSH.
So, I’ve read different opinions:
Wait for it, because NSA gnomes are going through all your files in search for **bleep**. This may take over 30 hours.
Return to RMA.
Dissasembly and unbrick it.
Burn it and jump over it’s dead body.
Since I NEED that **bleep** data and know the RMA service in Argentina, they would just give me a new one… After a month (if I’m lucky), I don’t think I’ll take that aproach.
Sorry to hear you are having problems accessing your files? Have you tried to contact tech support directly for assistance on this? They might be able to help with some options.
Sorry for the lost. Your data should be ok, hopefully. The unbricking process is actually quite easy ½ - 1hr process provided you have all the prerequisites (checkout my sig). I done it a few times…
Thanks. I guess I’ll have to go with it. Maybe during the week or next weekend.
