When will my replacement be shipped?
I have a need to get this quickly,
Can I track it?
Where do I find if it has been shipped?
Can I track it?
Hi you can go here and click on Warranty Status. http://support.wd.com/warranty/index_end.asp?lang=en .
Click the Kudos star to say thank you for helpful posts. And be sure to come back to click the ‘Accept as Solution’ button for the post that solved your issue.
I went to the link provided but could not find “Waranty Status” Only “Waranty Policy” and “Waranty Extension”. Niether answered my question.
It depends in the type of RMA you processed. Standard RMA ships after the original product is received while Advanced RMA ships 3-5 business days after the creation of the RMA order. Your RMA Pre-mailer will be updated with a tracking number once it ships.
Basic RMA information:
http://wdc.custhelp.com/app/answers/detail/a_id/8/
Current turn-around times:
http://support.wd.com/warranty/rmapost.asp?lang=en
RMA Pre-Mailer:
http://wdc.custhelp.com/app/answers/detail/a_id/143/
RMA Status:
http://wdc.custhelp.com/app/answers/detail/a_id/10/
Regards,
