Hi. I am trying to find out if the 1tb internal hard drive has a SATA interface which I could connect directly to a SATA interface. I don’t believe eSATA is complatible with SATA so I thought maybe I could use the drive another way by connecting it directly.
http://www.wdc.com/en/library/sata/4879-705015.pdf
Update:
According to other website forums, these disks could be IDE or sata. Also, the disk has firmware compatible with TivoHD.
So I will forget about using an internal drive for my requirement.
