Treid to store files from my laptop to my WD Passport, but only got a message about an “I/O Failure”.
Does anybody have experience with this? How should i solve it?
Usually that’s referring to cable problem. You should be using a cable shorter than 18". If you are try another cable and maybe another usb port.
