What compatible wireless N adapters will do 5GHz?
I’m ready to jump in and buy a WD TV Live but for now I will have to go wireless.  Can somebody please tell me what USB wireless adapters I can buy for the WD TV Live that will work on 5GHz?  I’d like to avoid 2.1GHz to keep the interference down and my router (Netgear WNDR3700) can definitely handle it.  Please tell me what my best options are.  Thanks!
Linksys WUSB600N
I just purchased this Linksys adapter WUSB600N V2 and a Linksys E2000. The WD Live Plus can not see the 5GHZ wireless N SSID, just the mixed 2.4 GHZ signal. I connected the adapter to my PC and it can see and connect to the N only signal.
Any help would be appreciated.
WD Live Plus 1.03.29_B
This may (or may not) help.
http://community.wdc.com/t5/Firmware/5Ghz-Network-issue-WDLive-with-WUSB600N-recognize-the-network/td-p/13360
