Hi everyone,
Does anyone know if it is possible to make webtv wifi compatible?
ex? a wireless usb port, will that work? or an external hard drive with wifi?
I’m looking to move into a building that offers free wifi and thinking of using webtv as my only tv source.
THANKS
The WD TV does not allow you to install an application directly to the device. What you can do is use your computer to stream to your WD TV Live Hub. There are several software that allow you to do so, Playon or TVserty
WebTV has nothing to do with the Live Hub. If you meant to ask about making a Live Hub wifi compatible, there is this sticky at the top of this forum.
http://community.wdc.com/t5/WD-TV-Live-Hub-General/Updated-list-of-compatible-devices-for-the-WD-TV-Live-Hub-Media/td-p/162270
There is also a more current list of approved USB devices to do just that on the WD website.
