I have a new WDTV Live, have a HDMI linking it to my Samsung TV. Everything was fine, but I’ve noticed a problem after a couple of days.
Normally, I will turn the WDTV on, go to the HDMI channel on the TV, I see the WD loading screen (the big WD logo) and so I know it’s the right channel, it then switches off / does something ‘off screen’ and then load up the main screen with the icons on. Job done.
Recently though it shows the WD screen, then when it ‘switches off’ the next screen doesn’t appear and the TV claims ‘Signal lost’. I turn off, back on, nothing. Usually I have to pull the ppower lead out of the back and put it back in to get this working!
Any ideas on what this could be? I upgraded the firmware to the new beta, so I was wondering if it was a beta issue…?
EDIT: I think this might be a similar issue to the one a couple of threads below from Franny… it sounds the same…
Nope, that didn’t help and a day later? Problem is still there. WD title screen, nothing after unless I pull the power cord out and put it back in.
Seriously getting close to sending this back and asking for a refund.
EDIT: Just seen on the Beta release page that the new .38 beta removes the ‘HDMI handshake issues introduced in 1.03.35V’. Which sounds like my problem, as I auto upgraded when I got this TO .35V.
So it looks like I’ll have to wait until the .38 update comes out. Any ideas when that would be?
What firmware are you on now? If you are on .35 you could go to 38.
