DervishWD wrote:
The MKV Toolnix and MakeMKV are two seperate programs, how does MakeMKV know to disable header removal… in the future?
It doesn’t, Pecker’s post you quote was misleading. MakeMKV does not touch the header removal setting, only mkvmergeGUI (part of the MKVtoolnix package) does. Until Mike adds zlib compression to MakeMKV, the workflow stays the same:
- Use MakeMKV to make an MKV (d’uh) from a Bluray, dropping all unwanted tracks.
- remux the mkv in MKVToolnix (with header removal compression disabled) which will automatically apply zlib
compression to any sub track.
