I just finished building my new rig and made sure I bought a M2 SSD that supported TRIM so I bought myself a WD Black PCIe 256GB because I love how well it keeps them running and according to Error it should work just fine but in my WD Dashboard v2.2.0.1 TRIM is greyed out and there is no way to turn it on. So it doesn’t seem to be an option…
I’m running the latest firmware I could find B35500WD.
Checking CrystalDiskMark TRIM also seems to be missing in the list.
I did the normal optimize drive through the disk defrag in win 10 and checked cmd for “fsutil behavior query DisableDeleteNotify” and set it was set to 0 so that would mean its on, yet nothing seems to register that it is.
It said it was not on or off for NeFS (or something like that) so I changed that to 0 as well just to be sure.
Using the Trim Checker tool it says its most likely working but I just don’t feel 100% certain about it.
My motherboard supports the card.
Z270 Gaming Pro Carbon Firmware BIOS v1.50 (7A63v15 which is the latest as far as the live updater and site say) and it’s connected to M2_1 for, those that happen to know the board, so its connected just fine.
Anyone any idea what could cause this? Mostly why I can’t seem to enable TRIM or make any program show up that it is enabled while it seems to be…?
