WDS120G2G0B and WDS120G1G0B difference
Hello. There are two WD Green 120G SSD M.2 drive models on the market, WDS120G2G0B and WDS120G1G0B. What is the difference?
Looks like one (WDS120G2G0B) has 3d NAND.
See HERE
WDS120G2G0B - SanDisk controller + 256 Gbit TLC 3D 64L V-NAND SanDisk
WDS120G1G0B - Silicon Motion SM2258XT + 15 nm TLC NAND SanDisk
Source –https://forums.overclockers.ru/viewtopic.php?f=24&t=570459&sid=5c400eb1826f34a9a1996e1a8c37788b
Hi Martin5,
So, this difference is able to define if my laptop is compatible just with one or both?
I want to know wich one i have to choose to install it into a HP 14-bp005la laptop?
Thanks in Advance,
WDS120G1G0B much better but hard to find, look for the Kingston A400
the tests show the opposite
