WDPS040RNN power supply EU plug
I have a WD Elements 1 TB and bought it in the UK, so I have the power supply and a UK plug. I want to get the EU plug now, as it is interchangeable, to use it elsewhere in the EU. But I can only find a spare power supply with both plugs in every shop, including the official WD store - I only want the EU plug though.
I hope you won’t tell me I have to buy a new power supply for 14,99 € just to get this small interchangeable plug.
Best regards
I’m not familiar with the plug differences I’m in the US. Do you have any general electronics suppliers like Radio Shack here they might have some adapter.
Joe
