WDLive Hub, Media Library, and FreeNAS
I’m missing something simple, but I can’t for the life of me find it…
I recently setup a FreeNAS box and it’s working great… I can get to it via the WDTV by folder, and I can add it to the Media Library… But, when I switch back from folder view to media view, the network share doesn’t show up.
I had it working before with just a straight samba share via linux, but when I switched to FreeNAS, I can’t get it back.
Are the files not showing even if you access your media through the main menu? I have not used a WDTV + FreeNAS combination, and as such I wonder if you encounter the same behavior when serving files from a Windows system.
Regards,
I’m not sure what you mean.
They show up fine in folder view, if I go to the files as a network share…
But if I add the network share to my media library, they never show up.
They did previously when it was a CentOS machine with just a normal samba share.
