My hard drive doesn’t report as 6.0 Gb/s in the BIOS. I’ve heard of a utlity that fixes this, WDSSPEED, but I can’t find it, and am unsure how to use it. Thanks for the help.
Check if the hard drive has a jumper on pins 5/6, that will also downgrade the speed. Also check if the link below helps.
Jumper settings
http://wdc.custhelp.com/app/answers/detail/search/1/a_id/5387#jumper
No jumpers installed. The links for the WDSPEED are dead, thats why I’m asking for it here.
bump
Its possible there may be a logical reason for that…
after reading that i thought well what if that is happening to you instead of being forced into a black screen problem as mentioned in that article.
maybe contact support about the issue.
solution 1 says
which might explain why this is one tool i never heard of before.
