WDC solid state replacement for wd5000BEKT-75KA9TD
I want to replace my WD 75KA9TD with a ssd that will be compatible with my laptop.
I wish to load Linux on this drive to have dual OS system on the laptop.
What is a ssd drive that will fit in the laptop.
Seems it’s a 2.5" drive so any 2.5 SSD should fit.
Thanks for the advice. I will try to see if it can fit in my laptop.
If your WD 75KA9TD is a 2.5-inch SATA drive, replace it with a 2.5-inch SATA SSD like Samsung 870 EVO, Crucial MX500, or WD Blue. These work with most laptops and support Linux for dual-boot. If your laptop has an M.2 slot, consider the Samsung 970 EVO Plus (NVMe) or Crucial MX500 (M.2 SATA).
Great feedback, I will try the WD Blue.
