wd6001fzwx - X99 chipset RAMPAGE V EDITION 10 - disconected problem !!! Please help !!!
Change sata cables and sata ports - still disconecter when rebot
Hi RobertTree,
Did you try to check after connecting the WD Black internal hard drive in other computer?
Hello, thanks for your support … I’ve dealt with the problem … I’ve reinstalled the chipset driver and for now everything works perfectly !!!
