Im getting more and more frustrated with WD.
1 year ago I bought 2 x MBWE II 6GB for my internal network and found that they crased all the time when transfering / copying files to them.
(Light Stuck, Network Drives not responding, Console not responding)
After posting here and only go one answer for somebody else who had the same problem, I stored them and bought a couple of Synology that works perfect.
It annoyed me though that I had them on the self with no use, so the other day I started to mess around with them again.
I updated to the lastest firmware and deactivated MioNet from advice from another post.
* Im running the raid as Stripe
* The MBWE has network connection, but not Internet connection
* I have tried resetting the box many times and start all over
* There is absolutely nothing of interest in any logs
Nothing helps, as soon as I start copying files to the box it dies after 15min to 2 hours.
Please WD … what am I to do ?
Continue buying Synology ?
