WD5000MT replacement cable
Hello, I own a WD5000MT. It’s came with a special cable. with a Mini USB (B) and a Mini Firewire400 on one side and a USB on the other side.
I lost my cable. I cannot find a replacement one on the WD online Store.
So look for a website to buy a replacement for this cable.
Thanks in advance for your help,
Best regards,
Jacques
My Passport USB Cable (USB Micro)
A replacement or additional USB cable to connect your
My Passport Portable hard drive to a PC or Macintosh computer.
Model: WDCA037RNN
$9.99
You can buy it direct from WD Store,
click here for the link to the store
http://store.westerndigital.com/store/wdus/en_US/DisplayAccesoryProductDetailsPage/ThemeID.1300400/productID.169044800/categoryID.13095900/parid.13092600/catid.13095900
No kudos. You didn’t read his post and that’s not the cable Jaques was looking for.
Your bad. :frowning:
Doug
ledzuscany
