WD4000AAKS-00TMA0 made in thailand 02 MAR 2007
DCM : HBNCHV2ABB
WWN : 50014EE2AA
PCB : 2061-701477-800-AB XC 4D04 0JUC
PWB : 2060-701477-001
Below of question has whole story I wrote.
Questions
I really hope to there is only PCB problem ( It has to be ) It’s just instantly gone.
- I have other two 4000AAKS-00TMA0 hdds. So I tried to swap PCB. but it was not work.
Two 4000aaks is PCB : 2060-701477-800 AB XS ~, made in Malayia, 27 Dec 2006, alos v2 mark on foxconn connector.
So I tryed 2061-701477-800-AB XC named pcb. However It was very difficut to get it.
This is question : How can I check compatible pcb for my HDD. Is there kind of version problem?
I found several 4000AAKS-00TMA0 ( also thailand ) however code was not same.
So I want to know It’s possible to change with other pcbs like AE XC or AF XT made in Thailand.
Is it possible to change with 5000AAKS pcbs or others?
I found many 5000AAKS has almost same PCB code also there is tons of 5000AAKS
2)I heared If I can get proper PCB, I can recover HDD even though Raid 0.
Is that correct? I learn there will be problem with ROM inclued serial number though.
- Where can I find good service provider. I know good HDD recovery service provider in South Korea.
But It was really expensive.
Frankly speaking I don’t have enough money to use HDD recovery service. So I’m trying DIY.
My english is not so good because of I’m not using enlish long time.
So please consider me.
I learnd english typing with old text adventure game like larry, king’s quest, search for the king etc…
This is my situation.
1)I’m using Raid0 with three WD 4000AAKS model.
I plug in my 400gb HDD to power cord and boot pc. ( I changed PSU )
Bios did’nt recognize 1 HDD, other two is OK>
) I tryed to figure it out what’s the problem.
So I changed cord then I find there is no motor sound.
Now I finally recognize I’m use wrong wired cord. It was my mistake.
I checked pub then I found It’s burued.
So I tryed to swap PCB with other Two. Motor sound is now working
But freeze when booting bios screen.
* other 2 4000aaks hdd was made in mayasia. and has little bit other pcb cord name.
2061-701477-800-AB XS 4D04 also there is V2 mark on foxconn connector.
I’ll attach photo
I believe pcb is just gone. So If I change compatible PC It’ll work.
However I found there is ROM and Serial Number trouble.
It take a long time for learing this problem.
Also I went to Korea biggest Computer Market ( Yong San ) then I failed to find same pcb.
Actually WD4000AAKS model was somthing rare even though there was lots of 320Gb and 500Gb.
I found just few of WD4000AAKS (made in thailand) and I took a pictures.
Thanks reading very long my bad englsih question.
I looking forward to your great suggestions.
Sorry. I think image link was missing. So I put them again.
I don’t understand why image is bronken again. I do again.
