I changed network mode to DHCP and it seems to be working. When I had it in static mode, I had 1 DNS address (my router’s address) entered. Is that correct? Subnet was 255.255.255.0
I would really prefer to have it set for static but am very happy it seems to be working at the moment. It’s going to bug as to why it’s not working in static mode until I firgure it out. ;)
The error code you’re receiving isn’t coming from your MBL – it’s coming from something else out on the internet – and I have no idea what it could be.
What you “should” see now that you’ve “fixed” it is:
Forbidden
You don't have permission to access /UI on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Can you confirm that?
BTW, my box is running a static IP and it’s working fine for me.
My only guess is that when you’re using DHCP, that somehow the UPnP reservation is getting messed up. Don’t have a clue about that.
I have been having problems getting wd2go work with my Ipad.
WDPhotos is fine.
I keep getting device offline.
I make chamges as suggested by other contributors and get as far as being able to list the folders, then when I click on a folder the Mybooklive hands and eventually gies a Device Offiline message.
I am using a SKY router which has a static ip addr for mybooklive.
I have created security rules to allow port forwarding on 80:443.
I deleted all mobile access on the remote access dashboard, then rebooted mybooklive.
I am at my wits end.
I was an IT professional but this has got me beat.
I have emailed WD but no response.
I have had a WDTV Live streaming for a while now and I suppose I should have learnt my lesson buying anpother WD product.
Their support is appalling and firmware updates seem to cause more problems than they solve.
I have an new MBL which can bee accessed from home via local wifi but not from say office via the wd2go. I have read the manual as well as sollutions from forums but failed to get it work. Could you post the sollution for this issue? Indeed, cloud accessing feature is one of the feature get me buy the MBL.
Regular users need a regular sollution but not the implied or technically complicated post without any help.
Many of the post here does not give any hint or sollution. They create more problems.
Mine just doesn’t even show on the app only option is to reactivate. Which can’t be done as accessing wd2go outside of my network where device is gives me a error 404 ?!!! And so can’t click link for remote access
In a office it connects fine
Every single virtual storage device is useless. Knowhow from pc world was rubbish as well.
That’s great you got the problem fixed. Please could you tell me how to do that. I am having the same issues since updating firmware and I think this might work for us. However, I am not too sure how I change the settings. thank!
In my case, WD2go works great when my MBLD is using DHCP and i doesn’t work when I am using static ip address.
What I could realize is that when I change my settings to Static IP, the MBLD doesn’t up the tun0 interface and the associated routes. WD any information about this ? Could this be the issue?
Below are my configs when using DHCP… it doesn’t exists when I using Static IP.
Please WD, tell me if it could be the reason for WD2go malfunction when I am using Static IP.
Same problem here. How sad that you buy a product and it does not work. You call tech support and they will trouble shoot for $14. I also have had this problem and would like a solution.
