Hello everyone
I have the WD2GO mobile app installed on my iPad. I have several .mp4 movie files stored on my MBLD. The files are from different sources, but all in .mp4 format. I am able to see, and play, most of them, but some are simply not visible in the app. The folder contaiing the video file IS visible, but not the video file itself. I have tried changing the file name, so that it didn’t contain any signs WD2GO perhaps didn’t support, but it didn’t work. The files are all playable when i access them on VLC. from my pc, for example. The size of the individual files in question are all under 2 GB. Some are converted films, some are recorded footage etc.
Since some are showing up and others aren’t this clearly does not have to do with the iPad itself not being able to play the files. Furthermore all the mentioned video files are playable through different apps on the iPad, for example buzz player. But since they can’t be used outside of my LAN this isn’t a viable option.
Anyone have any suggestions? Would be much appreciated…
