I had been reading a lot from this drive, I have a server with 6 of this drives, no issue yet, just wondering what is the read/write speed for this drives?
The manual just say 110MB.
I run this on Linux Centos 5.5 x64.
Running different benchmark tools I have this:
basic:
hdparm -Tt /dev/sdf && hdparm -Tt /dev/sdf && hdparm -Tt /dev/sdf
/dev/sdf:
Timing cached reads: 22752 MB in 1.99 seconds = 11426.02 MB/sec
Timing buffered disk reads: 344 MB in 3.02 seconds = 114.09 MB/sec
/dev/sdf:
Timing cached reads: 22752 MB in 1.99 seconds = 11424.32 MB/sec
Timing buffered disk reads: 352 MB in 3.01 seconds = 117.11 MB/sec
/dev/sdf:
Timing cached reads: 22736 MB in 1.99 seconds = 11416.38 MB/sec
Timing buffered disk reads: 352 MB in 3.01 seconds = 116.77 MB/sec
dd if=/dev/zero of=test1G bs=1M count=1024
1024+0 records in
1024+0 records out
1073741824 bytes (1.1 GB) copied, 7.11358 seconds, 151 MB/s
[root@mbx-xenserver files]# dd if=/dev/zero of=test2G bs=1M count=2048
2048+0 records in
2048+0 records out
2147483648 bytes (2.1 GB) copied, 19.2378 seconds, 112 MB/s
[root@mbx-xenserver files]# dd if=/dev/zero of=test4G bs=1M count=4096
4096+0 records in
4096+0 records out
4294967296 bytes (4.3 GB) copied, 47.9883 seconds, 89.5 MB/s
[root@mbx-xenserver files]# dd if=/dev/zero of=test8G bs=1M count=8192
8192+0 records in
8192+0 records out
8589934592 bytes (8.6 GB) copied, 97.6511 seconds, 88.0 MB/s
bonnie -s 2048 -v 3 -d ./ && bonnie -s 2048 -v 3 -d ./
Bonnie 1.4: File ‘.//Bonnie.7726’, size: 2147483648, volumes: 3
Writing with putc()… done: 77912 kB/s 93.3 %CPU
Rewriting… done: 45757 kB/s 1.0 %CPU
Writing intelligently… done: 86499 kB/s 7.9 %CPU
Reading with getc()… done: 76649 kB/s 88.5 %CPU
Reading intelligently… done: 120332 kB/s 0.3 %CPU
Seek numbers calculated on first volume only
Seeker 1…Seeker 2…Seeker 3…start 'em…done…done…done…
—Sequential Output (nosync)— —Sequential Input-- --Rnd Seek-
-Per Char- --Block— -Rewrite-- -Per Char- --Block— --04k (03)-
Machine MB K/sec %CPU K/sec %CPU K/sec %CPU K/sec %CPU K/sec %CPU /sec %CPU
mbx-xe 3*2048 77912 93.3 86499 7.9 45757 1.0 76649 88.5120332 0.3 102.7 0.1
Bonnie 1.4: File ‘.//Bonnie.7811’, size: 2147483648, volumes: 3
Writing with putc()… done: 77290 kB/s 92.9 %CPU
Rewriting… done: 46068 kB/s 1.1 %CPU
Writing intelligently… done: 87286 kB/s 7.8 %CPU
Reading with getc()… done: 73689 kB/s 85.2 %CPU
Reading intelligently… done: 120492 kB/s 0.3 %CPU
mbx-xe 3*2048 77290 92.9 87286 7.8 46068 1.1 73689 85.2120492 0.3 104.1 0.0
The server is running Xen kernel, this test are from the hypervisor with 2 cores dedicated and 1GB RAM dedicated to.
Do this numbers are in the normal performance?
What numbers do u have?
Thanks all for your time :smileyvery-happy:
