WD1002FAEX and Marvell 9123 Sata3 Controller issue
Hi all,
i have Asus p6x58d premium and i buy 4 WD1002FAEX (only 2 used with this motherboard).
If i connect this 2 hd to Marvell 9123 Sata3 controller i have this issue :
linux show me :
[1603.357567] ata7.00: exception Emask 0x10 SAct 0xffff SErr 0x580000 action 0x6 frozen
[1603.357572] ata7.00: irq_stat 0x08000000, interface fatal error
[1603.357576] ata7: SError: { 10B8B Dispar Handshk }
[1603.357580] ata7.00: failed command: WRITE FPDMA QUEUED
[1603.357586] ata7.00: cmd 61/00:00:3f:a8:eb/04:00:00:00:00/40 tag 0 ncq 524288 out
[1603.357587]          res 40/00:0c:3f:d0:eb/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
[1603.357590] ata7.00: status: { DRDY }
[1603.357593] ata7.00: failed command: WRITE FPDMA QUEUED
[1603.357599] ata7.00: cmd 61/00:08:3f:d0:eb/04:00:00:00:00/40 tag 1 ncq 524288 out
[1603.357600]          res 40/00:0c:3f:d0:eb/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
[1603.357698] ata7.00: status: { DRDY }
[1603.357701] ata7: hard resetting link
[1604.433297] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 370)
[1604.438382] ata7.00: configured for UDMA/133
[1604.438420] ata7: EH complete
The disk connected to port 0 of controller show this message, after ~ 3 cycle sata link up limited to 3.0 Gbps …
with windows if this disk it’s used as os disk (windows installed on it), os freeze … at reboot hd is not recognized from
marvell bios
There’s a firmware update for this hd ?
Other hd (C300 ssd for example) have the same issue and it’s released a new firmware for hd for bypass marvell controller bug.
For detailed issue description see this post on asus forum :
http://vip.asus.com/forum/view.aspx?board_id=1&model=P6X58D Premium&id=20100702050055531&page=1&SLanguage=en-us
Thanks for support.
Gabriele
