I just bought a Wireless Pro 4tb and I have a few questions.
First off can I have the drive access my home Wifi network without having to connect to the My passport network then through to my home network? When I connect through the drive first I loose the ability to use screen sharing with the Screens app (port mapping failed).
Secondly I cannot mount the drive wirelessly on my MacBook. (Mac OS 10.13) It works wired but when I try to connect when connected to my home network or the My passport network I get a prompt to login to the “MyPassport.local.” network and I cannot log in to it. I can see the drive with the iOS app in my iPhone and iPad and I can get to the Mypassport.local via the website but not in the finder.
Thanks for any Help
