WD Ultra 1TB does not start backing up
Hi all,
Hope to hear from you all to resolve this issue.
Bought a new WD Ultra 1 TB portable drive to back up my latop.
Installation went smoothly.
After I click Enable Backup, it did not back up anything even after 1 hour.
There is no indication of progress at all. I have chosen Category Backup and Continuous Backup. The software is WD SmartWare Pro.
When I tried to change to Hourly back and click Backup Now, it shows the error message: The RPC Server is Unavailable(Exception from HRESULT:0x800706BA) Laptop OS is Windows 8.1Pro.
Thanks in advance,
CH
Welcome to the Community.
This error message is uncommon. What happens if you switch to File Backup for testing purposes or re-install the application?
Hi Trancer,
Thanks for your suggestions.
  1. I did try switching to File Backup, but it’s same problem, it does not show any of activity.
  2. I have not tried uninstall and reinstalling, yet. This is probably the last resort, if there is no other way to resolve this.
Thanks,
CH
Hi chhee,
FWIW, I sol.ved my identical failure to start Ultra Backup problem by going to my Windows 7 Control Panel Backup and Restore Icon, and setting up a Backup from my laptop to my external WD My Passport Ultra device.  Initial Backup took about 5 hrs.
I don’t know if this will work for your  Windows 8 system but its worth a try.
Good luck Gramps3
