WD TW - HD media player - USB port problem
Is my media player done?
My problem: My player does not SEE my hard drives. It started with USB port 1 then I could use port 2 for 2 months. Now nothing happen when I plug my storages, it doesn’t matter which storage I try, USB key or mobile drive from WD. Do anyone have similar experience?
Regards,
Heimir
Have you tried resetting the unit via the side paperclip button. Press for 1 second and then release with the unit fully booted up.
Thank you for solving my problem!
Best regards,
Heimir
I have the same problem - and the paper clip solution did not work. The HD TV Live Plus was working until a few days ago when it updated itself  to the 1.04.18_B firmware. Since then, when I try to use a USB thumb drive (which had worked before) it says
“Unable to create media library on read-only storage.”
But the drive is Ext4. All the directories and files are 0777 (read, write, execute all).
Any clues/solutions would be greatly appreciated!
BTW, it does see files on network shares ok.
The Live NEVER worked with EXT4 file systems.
If it worked before, it was a fluke…
OK. Thanks. What format should I use??
NTFS / FAT32 / HFS+ (no journaling) all are supported.
