I have a WD TVLive Hub, and I can’t connect it into my computer using a USB to use the “drag-and-drop” method. It won’t show up in My Computer directory. How can I transfer the media files from my computer into it? Please show/tell me how to do it step-by-step. I don’t understand the firmware for it. Thanks! It would be much appreciated.
To drag and drop your content onto the hub you should connect the hub to your router and map a drive from your computer to the hub.
You will need to setup your network connection on the hub and make a note of the IP address.
Then from your computer goto Start -> Run and type [\IP](file://%5C%5CIP) address and Click ok.
You should then be able to navigate through the internal drive and drag and
Thanks a lot! :smiley:
