Hi, I cannot get the iPhone app for the WD TV to work with the iPhone 5. I’ve seen some reviews of the app that says it does a not work with the iPhone 5 and IOS 6. Is this correct and if so will WD release a fix or am I just doing something wrong? (There is a TV with a red line through it at the top of the app)
I have it working just fine on my iPhone 5 and the current iOS and it controls both my SMP’s just fine. Just make sure your phone is connected on the same wifi network. Occassionally I have to reset my router or the SMP itself for everything to see each other.
I have found that uninstalling an app that is not working right and then re-installing it can help sometimes. So, if all else fails, try this approach. Can’t hurt.
I assume that you have the Live streaming gen3 player or the WD live gen2 with latest firmware plus you have the player switched on and connected to the network.
