Just picked up a Live + a couple of days ago and I am not real pleased with it.
I have had network problems galore , but that is not the reason for this post.
I was watching a NetFlix movie this morning and had to run out to do an errand. I was gone for 45 minutes and when I got back home the movie was over and the Live+ was frozen ! Totally non - responsive.
The power light will not shut off and the system will not re-boot. I have done a quick reset - nothing - nada - zip - ziltch.
I have replaced the batteries in the remote - no joy. I checked to see if the remote is working with a digital camera – it is transmitting.
I have been fiddling around with getting this thing networked (without much succes) and I now am thinking that this thing is a brick.
I just started having this same problem. Maybe I will clarify issues.
I’ll be using my WD Live Plus. No problems with anything. Operation is normal. I have had it for about three weeks and operation has been totally normal up until three days ago.
I attempt to turn it off, the screen goes black, and the light on the Live stays on. The screen is blank, I don’t get the “check signal cable” or “no signal” dialog that shows up on my TV when its actually off. After that, the Live is frozen. The power indicator light stays on but there are no responses to the remote at all.
I have left it this way twice, once for 5 minutes and once for 20 minutes, in order to see if it would clear. No change.
The only way to fix this is to pull the power and let it reboot. When it starts back up, operation is normal, but the problem persists every time I try and shut it off. It is not intermittent.
My next step is to try a hard-reset and then, failing that, load up a prior version of the firmware.
So, do I have a bad Live, bad firmware, or is there something else going on?
