Hello guys,
I’ve got a WD connected to my router (Powerline) and 2 USB HD plugged in the 2 slots.
Apparently everything work very well, I see the net from WD and the WD is very well visible from the other devices.
NON SYSTEMATIC PROBLEM that occures very often: LAN connected or not, the AUDIO (mp3, videos, You Tube…) if OFF, NO AUDIO !!! By chance, when I flash it, then I can hear the same files mp3, videos, , YouTube…); later, agh…the same problem, no way to quietly hear the audio, even in a simple not LAN connected way…
DO YOU THINK GUYS IS IT A FIRMWARE PROBLEM ?
I have also noted that sometime WD starts to work with my USB HD and keep on flahing the USB fronta light for no reasons.
Any help ? Thanks
