hello,
i i have wd tv live hub media center, i connect to hdmi switcher then the swetcher connect to my digital too.
the output of switcher connec to hdmi spliter “four tv” i have sony bravia tv’s
when i switch to digtal everything work fine when i switch to wd tv live hub give me unsupported signal,
i try to cut 2mm from the hdm connector it’s work fine ! after i try to switch to digtal and back again i have the same problem ?
any solution for that?
thanks.
