after updating my tv live hub to 3.12.13 i get problem with wifi ,earlier my wifi work fine but now it is not working properly…
I used Wd router My Net N900 Central…and wifi of Asus which is compatible with tv live hub…
when i connect tv live hub with network then it connect after some time hub is disconnected automatically and reconnect…though i can able to use network and internet for 8-10 min properly then problem is started tv live hub automatically disconnect from network…please suggest what to do i also use another wifi dongle for live tv but problem remain same and i also factory reset my router and tv live hub please suggest solution…
