The software WD smartware is not installing.After correcting all the settings and when installation is in progress,an error comes up.The error is 0x00000 and thus the setup exits.
What Operating System are you using? Also what version of smartware are you trying to install?
OS: xp service pack II 32 bit 512 mb ram
You are getting a memory address error. Contact our support and get assistance with the installation. There may be other factors on your computer like .net frameworks or registry permissions issues.
