Wd smartware PRO does not recognize wd my cloud
I have the following device:
  • Windows 7 Home Basic
  • WDMyCloud 6 TB v04.04.02-105 : Core F/W
  • WD Smartware PRO 2.4.14
Previous actions:
  • I tried to re-install several times WD Smartware
  • Upgrade Core F/W to last version
  • Upgrade WD Smartware to last version
I can access to WDMyCloud by access page and Network without problems, but Smartware and Discovery don`t recognize My Cloud, any ideas?
Thank you.
Have you tried resetting the devices on the network? If not, please try resetting the My Cloud and the router.
Yes, I tried to restart all devices and is I had same problem. Also, I connected the machine to the Router directly even i had the same result.
Thanks.
