…on click (right or left) only provides for About WD Quick View.
Anyone else have this problem?
What can I do to enable the full popup menu options?
Thanks.
Thanks.
it means that the software isn’t seeing the drive. If you open a browser and type http://mybooklive/UI do you get the dashboard?
If not, you may have a DNS issue. Try changing the DNS address of the NIC or wifi adapter to 8.8.8.8 to see what happens.
Thanks for the response.
I suspect the problem is my PC. Several days ago I noticed the system tray was showing only a single icon, Norton. I googled the problem and found a fix that involved disabling two services < http://bit.ly/VheFSD>. That did the trick. But left the WD Quick View icon only partially enabled. So I thought the problem might be with the Mobile Book Live.
Thanks again. I’ll continue searching for a solution for the PC.
