I have the "Volume Datavolume does not exist on my WD Sharespace NAS. I received the replacement unit from WD. Can I just swap the drives and see if it works, or will that format the drives and loose my data. I bought a couple extra drives, so I can keep drive # 4 (sounds like that is normally the data drive). I have been trying to do the process mentioned by dudemanbubba, but my hardware on my desktop is really old and I have not been able to get it to work. I figured when I get a newer desktop, I will try it again. So do I try to swap all the old drives in, or will that cause them to be reformatted?
Thanks for the help.
