WD Red SMART load/Unload utility 3.5" Drive for 2.5" Drive
Is it possible to use the WD Red SMART load/Unload utility 3.5" Drive with 2.5" Drive like WD RED 1To WD10JFCX  ?
Regards
I found the load/Unload utility for 2.5" drive :
http://support.wdc.com/product/download.asp?groupid=706&sid=231&lang=fr
So this is not the same as for 3.5" drive
Regards
Hello and welcome to the WD community.
Thanks for sharing your solution. Hopefully this will help other users with a similar situation in the future.
