Hi I look after a large RAID5 array which is showing very slow writes. I’ve run long smartctltests on all the drives in the array and no errors are mentioned in the summaries. I am suspecting the following 2 drives - can anyone give me some advice please? I am looking at Raw_Read_Error_Rate and Multi_Zone_Error_Rate values and I’m thinking Drive 4 is probably in the worse shape. Here’s smartctl output from the long tests I ran last night:
Drive 0
smartctl 5.42 2011-10-20 r3458 [i686-linux-2.6.18-348.1.1.el5] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Western Digital RE4 Serial ATA
Device Model: WDC WD2003FYYS-02W0B0
Serial Number: WD-[[DELETED-Privacy]]
LU WWN Device Id: 5 0014ee 057f7a1ee
Firmware Version: 01.01D01
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Wed Oct 26 08:58:31 2016 BST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 253 253 021 Pre-fail Always - 8791
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 33
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 045 045 000 Old_age Always - 40571
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 31
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 30
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 2
194 Temperature_Celsius 0x0022 103 090 000 Old_age Always - 49
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 001 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 40567 -
# 2 Extended offline Completed without error 00% 39384 -
# 3 Short offline Completed without error 00% 39379 -
# 4 Short offline Completed without error 00% 39379 -
Drive 4
Serial Number: WD-[[DELETED - Privacy]]
LU WWN Device Id: 5 0014ee 600e61468
ATA Version is: 8
Local Time is: Wed Oct 26 08:59:53 2016 BST
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 46
3 Spin_Up_Time 0x0027 253 253 021 Pre-fail Always - 9250
9 Power_On_Hours 0x0032 045 045 000 Old_age Always - 40563
194 Temperature_Celsius 0x0022 099 087 000 Old_age Always - 53
200 Multi_Zone_Error_Rate 0x0008 195 195 000 Old_age Offline - 1044
No Errors Logged
# 1 Short offline Completed without error 00% 40562 -
# 2 Extended offline Completed without error 00% 40559 -
# 3 Short offline Completed without error 00% 39368 -
