Can a 1Tb purple drive use a 4pin Molex to 15pin sata power connector?
Where on the WD website are installation instructions/user manuals? Not under “installation guides” or “downloads”. Website is not very helpful!
I have not tried this because it is not supported. Lets see if another user can share some experience regarding this.
I was talking about a power cable, not a data cable.
BTW, I got the answer on Amazon.com, it is compatible.
the WDC website support section leaves alot to be desired.
It should work just fine… i have used before ide to sata without any kind of problems if you have a good power supply dont be afraid to use it
