WD Passport Wireless Pro "forgets" network
Setting up my wireless pro seems to work fine. However after turning it off or taking it away from the network, it fails to reconnect when it should. The link saved to my desktop works too until the device is turned off or taken out of wifi range.
Any suggestions?
https://support.wdc.com/knowledgebase/answer.aspx?ID=14204
@Sand531
Would you be willing to participate in our Public Beta?
https://community.wd.com/c/beta-programs/ppw-pro-firmware-beta
