Hi can I upgrade firmware if I have no firmware button in my WD Smartware settings to select?
Welcome to the Community.
Are you trying to update the firmware on the drive itself? If yes, you can download the firmware directly for the WD Support site.
See if the following link helps
http://www.wdc.com/wdproducts/wdsmartwareupdate/firmware.asp?id=wdfMP_Ultra&os=WIN
