Hi guys went to plug the wd passport in to wd live box all i am getiing is the blue lights flashing can here the drive going just nothing happening keeps on flashing when i plug it into the computer it cant find in the drive sometimes the computer freezes all all my photos are on it eveything was working ok at the weekend.
cheers for your help
Did you replace the USB cable? Is your hard drive detected within Windows Disk Management? If so, does it show your hard drive as RAW? Does it have a drive letter? Disk Management access instructions are available in the following link:
when i plug it into computer go to disk management its online D healthy primary partition when i try to open it i get D:\ is not accessible. Access is denied.
cheers for all your help
Does it list the file system (NTFS, exFAT) of the volume? If it does not, then the problem is the volume has lost the file system.
