WD MyCloud red led light
I am using a gen 2 WDMyCloud 6TB (firmware 5.15.106). This morning it is showing a red led light. I am able to access the drive via LAN (windows explorer) and also able to connect to the web UI, which shows it as healthy status.
Any ideas on what’s wrong with it?
@jay8383 Check your Alerts
Thank you so much for that! Clicked onto Alerts, and there was warning for updates on the Apps. Updated the apps, and so far the led light is solid blue. :smiley:
