WD Mybook 250GB Problem
I have 2 WD Mybook 250GB External drives. They are formatted in Linux. I am not using them from long time.
When I connected them to my laptop today, I am able to see 1 drive, I formatted it in windows.
The second one I am unable to see it, the power is OK because I can see the light, I here the sounds like the HDD is working but I am not sure, how can I check weather the HDD is OK or not.
Please help me out.
MY email ID [deleted for privacy]
If you have a Windows pc, you can download our DLG Diagnostics utility to check the drive’s SMART status and the surface of the platters for damage/bad sectors.  You can also run Windows error checking to make sure that the partition isn’t damaged or corrupted.
DLG Diagnostics
http://support.wdc.com/product/download.asp?groupid=608&sid=3&lang=en
Hi Bill
I Ran the DLG Diagnostic utility, I am unable to see the drive in diagnostic window.
I here the hard drive running sound.
Please help me.
Srinivas
I will try to get someone to help you.
Hi Bill
Thanks for ur help, today morning I tried again by changing cables, it worked atlast.
Once again thanks.
Srinivas Varaganti
Oh, cool.  I’m glad it got taken care of.  Thanks for posting the fix.
