WD My Passport Wireless Pro - can't connect to wifi
One day my passport lost connection to internet and I’m not able co connect passport to any wifi anymore.
I’m able to connect other device to passport using wifi, see all files and able to change configuration. When I go to wifi internet section, i can see all available wifi networks but when I try to connect, connection fails about 1m. Does not matter is wifi is password protected or not.
I tried to connect with different networks and problem is always the same.
I already tried factory rester few times and didn’t help.
Firmware version: 1.04.17
Any idea how to fix this? Everything was working before, just stopped wan day.
Update: I am able to connect to my wifi only when I remove the password, IDK if this will help somehow find the solution.
