Wd my passport password problem
Hello , i just put password on my WD and it works fine on my PC , then i try it on my friend PC i can’t unlock it…i install everything that i install on my PC but still can’t solve the problem…
if you are able to unlock the unit on your computer, you should be able to do it on any other computer… is the unit giving you the screen to unlock the drive or not?
