WD My Passport 1TB USB3.0 Portable Red Hard Drive help
WD My Passport 1TB USB3.0 Portable Red Hard Drive will not work on my tv any suggestions please
Your TV needs to support USB 3.0 devices; they require more power than USB 2.0 hard drives.
On the other hand, if this is the new WD My Passport then you may need to format it since few TV’s support the exFAT file system.
